Nii palju sai veel seda täiendatud, et arvestab ka võrgutasusid ja ette sai pistetud piirhind KOOS võrgutasuga.
Sisse said viidud Võrk2 kuutasuga ja Võrk5. Võrgutasu on meil juba elektrihinnaga samasse suurusjärku. Täiesti jabur. Kui hr Leivo juhtub seda nägema, võiks suve/talve vaheldumise muuta automaatseks.
Kood: Vali kõik
// This script divides day into heating windows, finds cheapest hour(s) from each window, and turns on your (water)heating for that time.
// It's scheduled to run daily after 23:00 to set heating windows for next day.
// by Leivo Sepp, 31.01.2023
// Energy Market price is downloaded from Elering API https://dashboard.elering.ee/assets/api-doc.html#/nps-controller/getPriceUsingGET.
// Set the country Estonia-ee, Finland-fi, Lthuania-lt, Latvia-lv
// No other countries support exist trough Elering API.
let country = "ee";
// This parameter used to set length in hours for heating window. In normal cases I would recommend to set it between 4 to 8, but can be 1-24 (24 is useless).
// Example: If heatingWindow=6, then heating windows are 00-05, 06-11, 12-17, 18-23. Inside of each heating window the script finds chepest prices depends on the next heatingTime parameter.
let heatingWindow = 12;
// This parameter used to set number of heating hours inside heating window. In normal cases it should 1 or 2 hours, but can also be bigger number.
// For example if this number is set to 1 then Shelly will turn on for 1 hour for each heating window.
let heatingTime = 3;
// Keep this parameter is_reverse=false, I think 99% of the situations are required so.
// Rarely some heating systems requires reversed relay. Put this "true" if you are sure that your appliance requires so.
// For example my personal ground source heat pump requires reversed management. If Shelly relay is activated (ON), then my heatpump is turned off.
let is_reverse = false;
let max_price = 80;
// This is timezone for EE, LT, LV and FI.
// Do not change this because it won't work currently for other timezones.
let timezone = 2;
let StartTime = "T22:00Z";
let EndTime = "T21:00Z";
let summertime = true;
if (summertime === true) {
  timezone = 3;
  StartTime = "T21:00Z";
  EndTime = "T20:00Z";
print("Timezone:",timezone);
// some global variables
let eleringUrl = "https://dashboard.elering.ee/api/nps/price";
let sorted = [];
let dateStart;
let dateEnd;
let shellyUnixtime = Shelly.getComponentStatus("sys").unixtime;
let totalHours;
let waterHeatingTimes = [];
let data_indx;
let countWindows = Math.floor(24 / heatingWindow);
// Võrk-5
let netprice = [29.5 , 29.5 , 29.5 , 29.5 , 29.5 , 29.5 ,29.5 , 51.4 , 51.4 , 79.4 , 79.4 , 79.4 , 51.4 , 51.4 , 51.4 , 51.4 , 79.4 , 79.4 , 79.4 , 79.4 , 51.4 , 51.4 , 29.5 , 29.5 ];
let netprice_weekend  = [29.5 , 29.5 , 29.5 , 29.5 , 29.5 , 29.5 ,29.5 , 29.5 , 29.5 , 29.5 , 29.5 , 29.5 , 29.5 , 29.5 , 29.5 , 29.5 , 46.0 , 46.0 , 46.0 , 46.0 , 46.0 , 46.0 , 29.5 , 29.5 ];
// Võrk-2
//let netprice = [32.8 , 32.8 , 32.8 , 32.8 , 32.8 , 32.8 , 32.8 , 56.7 , 56.7 , 56.7 , 56.7 , 56.7 , 56.7 , 56.7 , 56.7 , 56.7 , 56.7 , 56.7 , 56.7 , 56.7 , 56.7 , 56.7 , 32.8 , 32.8 ];
//let netprice_weekend  = [32.8 , 32.8 , 32.8 , 32.8 , 32.8 , 32.8 ,32.8 , 32.8 , 32.8 , 32.8 , 32.8 , 32.8 , 32.8 , 32.8 , 32.8 , 32.8 , 32.8 , 32.8 , 32.8 , 32.8 , 32.8 , 32.8 , 32.8 , 32.8 ];
print("Count of Heating windows",countWindows);
let year;
let month;
let date;
// Crontab for running this script.
// This script is run at random moment during the first 15 minutes after 23:00
// Random timing is used so that all clients wouldn't be polling the server exactly at same time
let minrand = JSON.stringify(Math.floor(Math.random() * 15));
let secrand = JSON.stringify(Math.floor(Math.random() * 59));
let script_schedule = secrand + " " + minrand + " " + "23 * * SUN,MON,TUE,WED,THU,FRI,SAT";
// Number for this script. If this doesn't work (as in earlier versions), get it from this url (use your own ip) http://192.168.33.1/rpc/Script.List
// You can check the schedules here (use your own ip) http://192.168.33.1/rpc/Schedule.List
let script_number = Shelly.getCurrentScriptId();
Shelly.call("ScriptSetConfig", {"id":script_number, config:{"enable":true}});
// This is the main function to proceed with data management, price sorting etc.
function find_cheapest() {
    let addDays = -1; //yesterday, used in case the scipt started before 3PM and we don't have tomorrow prices
    let shellyHour = JSON.parse(unixTimeToHumanReadable(shellyUnixtime, timezone, addDays).slice(11, 13));
    // Only after 3PM this script can calculate schedule for tomorrow as the energy prices are not available before 3PM
    // Running this script before 3PM, today energy prices are used.
    if (shellyHour >= 15) {
        addDays = 0
    // Let's prepare proper date-time formats for Elering query
    let shellyTime = unixTimeToHumanReadable(shellyUnixtime, timezone, addDays);
    let shellyTimePlus1 = unixTimeToHumanReadable(shellyUnixtime, timezone, addDays + 1);
    dateStart = shellyTime.slice(0, 10) + StartTime;
    dateEnd = shellyTimePlus1.slice(0, 10) + EndTime;
    // Extract Shelly year, month and day
    let dateTime = unixTimeToHumanReadable(shellyUnixtime, timezone, 0);
    year = JSON.parse(dateTime.slice(0, 4));
    month = JSON.parse(dateTime.slice(5, 7));
    date = JSON.parse(dateTime.slice(8, 10));
    // Let's get the electricity market price from Elering
    print("Starting to fetch market prices from Elering from ", dateStart, " to ", dateEnd, ".");
  print(eleringUrl + "?start=" + dateStart + "&end=" + dateEnd);
      Shelly.call("HTTP.GET", { url: eleringUrl + "?start=" + dateStart + "&end=" + dateEnd }, function (result) {
        if (result === null) {
            // If there is no result, then heating windows are starting exactly at midnight 00:00
            print("Fetching market prices failed. Adding default heating windows.");
            setTimer(is_reverse, heatingTime);
            for (let i = 0; i < countWindows; i++) {
                let unixtime = dateTimeToUnixTime(year, month, date, (i * heatingWindow) - 2, 0);
                // filling up array with the unixtimestamps
                waterHeatingTimes.push({ timestamp: unixtime });
        else {
            // Let's hope we got good JSON result and we can proceed normally
            // Example of good json
            // let json = "{success: true,data: {ee: [{timestamp: 1673301600,price: 80.5900},"+
            // "{timestamp: 1673305200,price: 76.0500},{timestamp: 1673308800,price: 79.9500}]}}";
            print("We got market prices from Elering, going to do the heating window logic ...");
            let json = JSON.parse(result.body);
            let pricesArray = json["data"][country];
            let arrayWindow = [];
            let LastUnixHour = pricesArray[23].timestamp;
            let DayOfWeek = Math.floor((LastUnixHour / 86400) + 4) % 7;
            print("Day Of Week: ",DayOfWeek);
            if (DayOfWeek > 5) { netprice = netprice_weekend }
            // Creating array for each heating window, sorting array, and then pushing smallest prices to waterHeatingTimes[]
                let k = 0;
                let hoursInWindow = (i + 1) * heatingWindow > 24 ? 24 : (i + 1) * heatingWindow;
                for (let j = i * heatingWindow; j < hoursInWindow; j++) {
                    arrayWindow[k] = pricesArray[j];
                    arrayWindow[k].price = arrayWindow[k].price + netprice[j]
                    k++;
                // Sort prices from smallest to largest
                sorted = sort(arrayWindow, "price");
                let heatingHours = sorted.length < heatingTime ? sorted.length : heatingTime;
                for (let x = 0; x < heatingHours; x++) {
                    waterHeatingTimes[(i * heatingTime) + x] = sorted[x];
        // // The fact is that Shelly RPC calls are limited to 5, one is used already for HTTP.GET and we have only 4 left.
        // // These 4 RPC calls are used here.
        totalHours = waterHeatingTimes.length;
        data_indx = (totalHours - 4) < 1 ? totalHours : 4;
        print("Starting to add hours 0-3");
        addSchedules(waterHeatingTimes, 0, data_indx);
        // // This is the hack with the timers to add more RPC calls. We simply add a 4 second delay between the timer actions :)
        // // Timers are called four times and each timer has four RPC calls to set up alltogether maximum 20 schedules.
        // // The Timers in Shelly script are limited also to 5, as one is used to stop the script itself we can call maximum 4 timers.
        // // For some reason I couldn't make this code smarter as calling timers seems not working from for-loop which would be the normal solution.
        if (totalHours - 4 > 0) {
            Timer.set(5 * 1000, false, function () {
                data_indx = (totalHours - 9) < 1 ? totalHours : 9;
                print("Starting to add hours 4-8");
                addSchedules(waterHeatingTimes, 4, data_indx);
        if (totalHours - 9 > 0) {
            Timer.set(10 * 1000, false, function () {
                data_indx = (totalHours - 14) < 1 ? totalHours : 14;
                print("Starting to add hours 9-13");
                addSchedules(waterHeatingTimes, 9, data_indx);
        if (totalHours - 14 > 0) {
            Timer.set(15 * 1000, false, function () {
                data_indx = (totalHours - 19) < 1 ? totalHours : 19;
                print("Starting to add hours 14-19");
                addSchedules(waterHeatingTimes, 14, data_indx);
        if (totalHours - 19 > 0) {
            Timer.set(20 * 1000, false, function () {
                data_indx = (totalHours - 24) < 1 ? totalHours : 24;
                print("Starting to add hours 19-23");
                addSchedules(waterHeatingTimes, 19, data_indx);
// Add schedulers, switching them on or off is depends on the "is_reverse" parameter
function addSchedules(sorted_prices, start_indx, data_indx) {
    for (let i = start_indx; i < data_indx; i++) {
        let hour, price;
        if (sorted_prices.length > 0) {
            hour = unixTimeToHumanReadable(sorted_prices[i].timestamp, timezone, 0).slice(11, 13);
            price = sorted_prices[i].price;
        else {
            hour = JSON.stringify(start_indx);
            price = "no price.";
    if (price < max_price) {
        print("Scheduled start at: ", hour, " price: ", price);
        // Remove leading zeros from hour
        if (hour.slice(0, 1) === "0") { hour = hour.slice(1, 2); }
        // Set the start time crontab
        let timer_start = "0 0 " + hour + " * * SUN,MON,TUE,WED,THU,FRI,SAT";
        // Creating one hour schedulers
        Shelly.call("Schedule.Create", {
            "id": 0, "enable": true, "timespec": timer_start,
            "calls": [{
                "method": "Switch.Set",
                "params": {
                    "on": !is_reverse
function dateTimeToUnixTime(year, month, day, hh, mm) {
    let month_yday = [0, 31, 59, 90, 120, 151, 181, 212, 243, 273, 304, 334];
    let year_adj = year + 4800;  /* Ensure positive year, multiple of 400. */
    let febs = year_adj - (month <= 2 ? 1 : 0);  /* Februaries since base. */
    let leap_days = 1 + Math.floor(febs / 4) - Math.floor(febs / 100) + Math.floor(febs / 400);
    let days = 365 * year_adj + leap_days + month_yday[month - 1] + day - 1;
    return (days - 2472692) * 86400 + hh * 3600 + mm * 60;  /* Adjust to Unix epoch. */
// Shelly doesn't support any date-time management.
// With this very basic math we can convert unix time to Human readable format
function unixTimeToHumanReadable(seconds, timezone, addDay) {
    //add timezone
    seconds += 60 * 60 * timezone;
    //add days
    seconds += 60 * 60 * 24 * addDay;
    // Save the time in Human readable format
    let ans = "";
    // Number of days in month in normal year
    let daysOfMonth = [31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31];
    let currYear, daysTillNow, extraTime,
        extraDays, index, date, month, hours,
        minutes, secondss, flag = 0;
    // Calculate total days unix time T
    daysTillNow = Math.floor(seconds / (24 * 60 * 60));
    extraTime = seconds % (24 * 60 * 60);
    currYear = 1970;
    // Calculating current year
    while (true) {
        if (currYear % 400 === 0
            || (currYear % 4 === 0 && currYear % 100 !== 0)) {
            if (daysTillNow < 366) {
                break;
            daysTillNow -= 366;
        else {
            if (daysTillNow < 365) {
                break;
            daysTillNow -= 365;
        currYear += 1;
    // Updating extradays because it will give days till previous day and we have include current day
    extraDays = daysTillNow + 1;
    if (currYear % 400 === 0 ||
        flag = 1;
    // Calculating MONTH and DATE
    month = 0; index = 0;
    if (flag === 1) {
        while (true) {
            if (index === 1) {
                if (extraDays - 29 < 0)
                    break;
                month += 1;
                extraDays -= 29;
            else {
                if (extraDays - daysOfMonth[index] <= 0) {
                    break;
                month += 1;
                extraDays -= daysOfMonth[index];
            index += 1;
    else {
        while (true) {
                break;
            month += 1;
            index += 1;
    // Current Month
    if (extraDays > 0) {
        month += 1;
        date = extraDays;
    else {
        if (month === 2 && flag === 1) {
            date = 29;
        else {
            date = daysOfMonth[month - 1];
    // Calculating HH:MM:SS
    hours = Math.floor(extraTime / 3600);
    minutes = Math.floor((extraTime % 3600) / 60);
    secondss = Math.floor((extraTime % 3600) % 60);
    //add leading 0 to month, date, hour, minute, and seconds
    let monthStr = month < 10 ? "0" + JSON.stringify(month) : JSON.stringify(month);
    let dateStr = date < 10 ? "0" + JSON.stringify(date) : JSON.stringify(date);
    let hoursStr = hours < 10 ? "0" + JSON.stringify(hours) : JSON.stringify(hours);
    let minutesStr = minutes < 10 ? "0" + JSON.stringify(minutes) : JSON.stringify(minutes);
    let secondsStr = secondss < 10 ? "0" + JSON.stringify(secondss) : JSON.stringify(secondss);
    ans += JSON.stringify(currYear);
    ans += "-";
    ans += monthStr;
    ans += "-";
    ans += dateStr;
    ans += " ";
    ans += hoursStr;
    ans += ":";
    ans += minutesStr;
    ans += ":";
    ans += secondsStr;
    // Return the time
    return ans;
// Shelly doesnt support Javascript sort function so this basic math algorithm will do the sorting job
function sort(array, sortby) {
    // Sorting array from smallest to larger
    let i, j, k, min, max, min_indx, max_indx, tmp;
    j = array.length - 1;
    for (i = 0; i < j; i++) {
        min = max = array[i][sortby];
        min_indx = max_indx = i;
        for (k = i; k <= j; k++) {
            if (array[k][sortby] > max) {
                max = array[k][sortby];
                max_indx = k;
            else if (array[k][sortby] < min) {
                min = array[k][sortby];
                min_indx = k;
        tmp = array[i];
        array.splice(i, 1, array[min_indx]);
        array.splice(min_indx, 1, tmp);
        if (array[min_indx][sortby] === max) {
            tmp = array[j];
            array.splice(j, 1, array[min_indx]);
        else {
            tmp = array[j];
            array.splice(j, 1, array[max_indx]);
            array.splice(max_indx, 1, tmp);
        j--;
    return array;
    // Huhh, array is finally sorted
// Delete all the schedulers before adding new ones
function deleteSchedulers() {
    print("Deleting all existing schedules ...");
    Shelly.call("Schedule.DeleteAll");
// Set countdown timer to flip the Shelly status
// Auto_on or auto_off is depends on the "is_reverse" parameter
// Delay_hour is the time period in hour. Shelly needs this in seconds.
function setTimer(is_reverse, delay_hour) {
    let is_on = is_reverse ? "on" : "off";
    print("Setting ", delay_hour, " hour auto_", is_on, "_delay.");
    Shelly.call("Switch.SetConfig", {
        "id": 0,
        config: {
            "name": "Switch0",
            "auto_on": is_reverse,
            "auto_on_delay": delay_hour * 61 * 60,
            "auto_off": !is_reverse,
            "auto_off_delay": delay_hour * 61 * 60
function scheduleScript() {
    print("Creating schedule for this script with the following CRON", script_schedule);
    Shelly.call("Schedule.create", {
        "id": 3, "enable": true, "timespec": script_schedule,
        "calls": [{
            "method": "Script.start",
            "params": {
                "id": script_number
function stopScript() {
    // Stop this script in 1.5 minute from now
    Timer.set(100 * 1000, false, function () {
        print("Stopping the script ...");
        Shelly.call("Script.stop", { "id": script_number });
deleteSchedulers();
find_cheapest();
setTimer(is_reverse, 1);
scheduleScript();
stopScript();
