PILT 2 PILT 3 PILT 4
Lisainfo:
Inner tank, the acid-resistant SUS 304-2b / stainless steel 0.4 mm.
Outer Tank coated with PVDF 0.4 mm. Insulation 50 mm polyurethane foam.
Vacuum tubes: thickness 58 mm x length 1800 mm. Diameter - vacuum tube 58 mm outside and 47 mm inside.
Metal mount, can be installed on both flat and slanted roofs.
CE certificate included.
yksxjan@hot.ee / 56561000
Hind: tee oma pakkumine!
