Vaillant recoVAIR 350 vent seade eesti oludes?
Postitatud: 11 Veebr 2013, 21:07
Mida arvata Vaillant recoVAIR vent seadmest eesti oludes?
Seadme tehn spetsis on kirjas min õhutemperatuur -7 kraadi.
Niipalju kui mina aru saan siis sellel seadmel puudub õhu eelsoojendi.
Kas see seade töötab eesti oludes normaalselt?
http://www.vaillant.co.uk/trade/product ... ecovair-t/
inffi kah lisaks:
System reference VAR 350
Nominal air flow m3/h 350
Nominal external static pressure Pa 265
Maximum air flow m3/h 350
Minimum air flow m3/h 70
Maximum efficiency % 95.1
Filter class EU G3 as Standard (F6 optional)
Sound pressure level @ 1m dbA 52
Power
Voltage/Frequency V/Hz 230/50
Power @ 30% 30
Power @ 60% 85
Power @ 100% 295
Operating temperatures
Maximum ambienttemperature ºC 40
Frost protection mode ºC -7
SAP Appendix Q Data (as measured by BRE)
Heat exchange efficiency level (%) Up to 85% Up to 85%
Specific fan power (W/l/s) Down to 0.9 Down to 0.9
inffi kah lisaks:
Power
Power @ 30% 30
Power @ 60% 85
Power @ 100% 295
