M: Hyundai HY2000SEi el. generaator, puldiga
Postitatud: 08 Sept 2015, 15:45
				Väga vähest kasutust leidnud, praktiliselt uus. Väga hea vaikne(müra tase 58dBA 7 meetrit) ja stabiilne bensiini generaator, puldist käivituv, kaasa ka 2 pulti, saab käivitada kuni 20m kauguselt. 4,5l kütusepaak kestab kuni 9 tundi. Asub Põlvamaal. Vajadusel saab toimetada ka Tartusse.
- Max. Output: 2.2kW / 2200w
- Max. Continuous Output: 2.0kW / 2000w
- Power Output: 4.9hp
- Frequency: 50Hz
- Voltage: 230v
- Current (A): 9.54A Maximum
- Engine: Hyundai HX125, 4.9hp Motor, 4-Stroke OHV
- Displacement: 125cc
- Starting Method: Electric / Remote Key / Pull Start
- Outlets: 2x230v (AC),1x12V 8.3a (DC)
- Fuel Type: Unleaded Petrol
- Fuel Capacity: 4.5 Litres
- Running Time: Up to 9 hours
- ECO-Throttle System
- Low Oil Shut Down: Yes
- Digital Overload Protection: Yes
- Noise Level: 58dB @ 7m (with no load)
- Frame: 3mm Polypropylene, Blue
- Dimensions: L: 551mm x W: 308mm x H: 488mm
- Weight: 28kg
Hind 700.- Kui oskad siis saab ka tingida!
Tel 5031210
- Frequency: 50Hz
- Voltage: 230v
- Weight: 28kg
Tel 5031210
