M kupank-inverter-laadija-BLUETTI EB70 716Wh/1000W Solar Portable Power Station
Postitatud: 30 Apr 2022, 12:53
Postitas Viki2
Pakkumisel on kupank-inverter-laadija-BLUETTI EB70 716Wh/1000W Solar Portable Power Station
Lisainfot: https://www.akromex.com/eshop/product.p ... roduct=451
Massive 716Wh capacity and 1000W rated wattage
The ultra-stable LiFePO4 battery chemistry,2500+ life cycles
2*230V AC outlets, 2*100W PD ports, 2*5V/3A USB-A ports, 2*regulated 12V/10A DC outputs, 1*12V/10A car port,1*15W wireless charging pad.
With max input of 200W, this power station can be fully recharged in 3-4 hrs with solar panels (OCV 12-28V, 200W)
It can also get fully recharged from an AC wall outlet in 3-4 hrs or a 12V car port in 7-8 hrs.
Weight:
9.7 kg (21.4lb)
Dimensions (LxWxD):
32*21.6*22.1cm(12.6*8.5*8.7 in)
Operating Usage Temperature:
-10-40℃
Certification:
CEC, DOE, FCC, QC3.0, CA Prop 65
Warranty:
24 Months
Re: M kupank-inverter-laadija-BLUETTI EB70 716Wh/1000W Solar Portable Power Station
Postitatud: 25 Juun 2022, 10:05
Postitas Viki2
Nüüd saadaval kerged 100W päiksepaneelid, mis sobivada suvilasse, matkaautole ja mesilaste kaitseks karude eest elektrikarjuse toiteks - lisainfot ka https://www.akromex.com/eshop/product.p ... roduct=341
Postitatud: 17 Juul 2022, 11:55
Postitas Viki2
Akupank 10kWh- 48V
Akupank 10kWh- 48V
Saabusid suured akupangad 10kWh, 48V - viide https://www.akromex.com/eshop/product.p ... roduct=455
Postitatud: 21 Aug 2022, 14:06
Postitas Viki2
Saab pakkuda hübriidinverterit 10kW ja 15kW -lisainfot ka https://www.akromex.com/eshop/product.p ... roduct=462
