Bosch gbh 36 v-li
peak
Bosch gbh 36 v-li
Lugemata postitus Postitas peak »
Bosch GBH 36 V-LI täiesti uus, kordagi pole olnud töös. 2 akut ja laadija
Rated power input 600 W
Max. impact energy 2,8 J
Impact rate at rated speed 0 – 4.260 bpm
Rated speed 0 – 960 rpm
Battery voltage 36 V
Battery capacity 4 Ah
Weight incl. battery 4,5 kg
Length 396,0 mm
Width 107,0 mm
Height 221,0 mm
Toolholder SDS-plus
Hetke hind:450€
Poes hind:900
NUMBER:53090491
Selline ta siis on..
peak
Re: Bosch gbh 36 v-li
hind on tingitav
peak
MÜÜDUD!!!
Suletud
