kristjanpre@msn.com
Kristjan
Asub Rõngus
Hind: 900€
Construction :Cast iron firebox with steel panels
Extraflame Standard model :Burgundy Red
Heat output:Output nominal 2:6kW - 7:0kW
Fuel type(s):Wood Pellets
Efficiency:>87%
Weight116kg
DIMENSIONS (standard)
Height :1036mm
Width :494mm
Depth :498mm
Flue diameter :80mm rear
Hopper capacity :15kg
Electrical consumption :60 – 80w
Hourly consumption :0.6 – 1.6kg per hour
Electrical ignition & Weekly programmer :Yes
							M: Pelletkamin Graziosa Steel
				KristjanP77
