tuulegenekas
insippo
- On tänanud: 6 korda
- On tänatud: 5 korda
tuulegenekas
insippo
Re: tuulegenekas
insippo
Re: tuulegenekas
QUOTATION LIST FOR 1KW WIND TURBINE
6 Picture & Item NO. Description FOB Shenzhen
(USD)
7 Head parts: Weight: 98kg USD444.20/set
8 Rated Power: 1000W
9 Maximum output: 1500W
10 Rated AC output: 220V
11 Rated DC output: 48V
12 Võimalik, et teie brauser ei toeta selle pildi kuvamist. Rotor diameter: 2.8m
13 Rated wind speed: 9m/s
14 Working wind speed: 3~20m/s
15 Speed regulation method: Mechanical yawing + Electromagnetic brake
16 Rate RPM: 500r/m
17 Generator style: 3-phase AC PM
18 Blade material & quantity: Fiber glass / 3pcs
19 2-in-1 Inverter & Controller: Weight: 14.50kg USD262.70/set
20 FD2.8-1.0 Controller: Off-grid
21 Inverter: Off-grid, Sine wave
22 Inverter & Controller: Weight: USD1112.10/set
23 Controller: On-grid
24 Inverter: On-grid, Sine wave
25 Tower: /
26 Guyed Tower: 6m, 75kg USD150.90/pc
27 Free standing tower: 9m, 360kg USD603.50/pc
28 Võimalik, et teie brauser ei toeta selle pildi kuvamist. GEL Battery: Weight: 180kg USD661.80
29 Capacity: 12V150AH*4
30 Gross weight: 180kg
31 Volume: 0.079CBM
32 GEL Battery working condition: -20degree to +50degree
33
34 Remarks:
35 1. Payment Terms: T/T 50% deposit when order confirmed, balance should be paid before delivery;
36 2. Delivery Time: 15 working days after received your deposit.
37 3. MOQ: 1 set
38 4. Capacity: 300sets / month
39 5. Warranty time: 2 years for alternator, 1 year for blades, battery, inverter & controller.
40 6. Life time: 15 years
41 7. Certification: CE approval, Rohs, ISO9001
42 8. Package: Wooden package
ja siin mis hinda küsitakse?
- On tänatud: 66 korda
Re: tuulegenekas
http://uudised.err.ee/index.php?06157322
kui tõsine huviline oled, mine uuri järgi kui kaugel nad omadega on. Äkki annab referensieksemplar välja kaubelda? Paned üles ja hakkad huvilistele 10.- tükk pileteid müüma
suured tuulejaamad toodavad aastas vati kohta 3 kilovatt-tundi energiat.
oma pisikesega sa vast üle kilovatt-tunni kätte ei saa.
seega 1000W genekaga aastas 1000 kWh energiat mis EE-lt ostes maksaks vast 1500 krooni (aasta paari pärast 2000-3000 krooni).
No ja kui saaksidki 2000 kWh, siis vastavalt 3000 (4000-6000) krooni.
Einoh - huvi pärast paneks isegi oma maamajja sihukese asja üles, aga akudega küll jändama ei hakkaks. Ahju paneks elektritennid ja las ta talvel siis kütab, jääb mõni puusületäis rohkem kuuri alles. Boilerit võib kah soojana hoida.
Mõne aasta pärast läheb päikesepaneelide hind kah taskukohasemaks - need saaks sinna paralleeli ühendada.
Küte ja soe vesi on kõige energiamahukamad asjad.
Aga kvaliteetelektri ostaks ikkagi võrgust.
insippo
Re: tuulegenekas
Analüütik
Re: tuulegenekas
Lugemata postitus Postitas Analüütik »
Paneme siia kõrvale lihtsa arvutuse tavapärase võrguühenduse kulude arvestuseks. Oletame, et soovitav tarbimiskoht asub niinimetatud "määratud piirkonnas" ja vajalik on peakaitse 3x16A. Liitumistasuks tuleb siis 33600.- krooni. "Tuul+päike" lahenduse rahast jääks järele peale liitumistasu tasumist pisut enam kui 215000.-. Võtame nüüd elektri hinnaks keskmiselt 1,5 kr/kWh ja esialgse tarbimissoovi (1500kWh/aastas) ja mis me näeme? "Tuul+päike" lahenduse raha eest saab liituda võrguettevõttega ja esialgse tarbimisprognoosi alusel tarbida ligi 100 aastat!!! Oletame, et elektrihind kahekordistub. Siis on võimalik sama raha eest tarbida "kõigest" 50 aastat. Teeme õige pilti veel reaalsemaks. Kardetavasti on selle "tuul + päike" süsteemi eluiga parimal juhul maksimaalselt 20 aastat (kuigi arvan selle olevat kaks korda lühema, kuid see selleks). Algandmeid arvesse võttes kujuneb elektrienergia hinnaks enam kui 8 kr/kWh!!! NO COMMENTS või mis? Ei tasu unustada, et tavavõrgus piirab tarbimisvõimsuse tippe peakaitse 3x16A, kuid "tuul+päike" lahenduse korral jääb veekeetja, triikraua ja pesumasina üheaegne kasutamine uduseks unistuseks.
Re: tuulegenekas
Kahtlemata on sul hetkel õigus. Kuid sarnaste analüüsidega hobuse kasuks esineti ka siis, kui ilmusid esimesed autod. Liiguti suuremalt väiksemale.Analüütik kirjutas:..... Algandmeid arvesse võttes kujuneb elektrienergia hinnaks enam kui 8 kr/kWh!!! NO COMMENTS või mis? Ei tasu unustada, et tavavõrgus piirab tarbimisvõimsuse tippe peakaitse 3x16A, kuid "tuul+päike" lahenduse korral jääb veekeetja, triikraua ja pesumasina üheaegne kasutamine uduseks unistuseks.
Esmalt hakkas hobust asendama vedur, siis tuli auto ja lõpuks mootorratas ja roller.
Ja hobune maksab täna autost rohkem..
Suured tuulepargid on juba enam-vähem OK, päikeseenergia on kohe-kohe konkurentsivõimeline lõuna-euroopas, ja küll need väiketarbijate kompleksjaamad kah kunagi valmis tehakse.
See ei tähenda, et ise põlve otsas nokitsemisega kokkuvõttes kasumlik asi kokku saadakse - siin on vaja tootearendust ja masstootmist.
Hea näide on soojuspumbad - idee külmkapp tagurpidi tööle panna pole ju uus. Aga kuupalga maksvaid COP 3-4 seadmeid ise põlve otsas valmis ei tee...
insippo
Re: tuulegenekas
Vaadates päikesepaneeli elementide hindu siis ja usas no kuhu kurat me nii jõuame.Hinnd on välismaal 1w=1$ aga mis meil on?
Re: tuulegenekas
?insippo kirjutas:.......Vaadates päikesepaneeli elementide hindu siis ja usas no kuhu kurat me nii jõuame.Hinnd on välismaal 1w=1$ aga mis meil on?
no telli siis USA-st - ega muidu asi ei parane..
nõudmise ja pakkumise vahekord on asja nimi..
PV panelide hinnad kukuvad lähiaastatel ilmselt veel üksjagu - üha rohkem firmasid on teatanud odavamate tehnoloogiate väljatöötamisest.
Seni aitab kõige suuremast hädast üle ka varugeneraator...
insippo
Re: tuulegenekas
Re: tuulegenekas
Lugemata postitus Postitas essa »
Ise eelistaks ka päikese paneele kuna liikuvaid osasid pole, peab ootama kui hinnad langevad.
- sashaobrok
- On tänanud: 36 korda
- On tänatud: 43 korda
Re: tuulegenekas
insippo kirjutas:Hinnd on välismaal 1w=1$ aga mis meil on?
Viska mingeid linke või midagi kus on 1 vatt 1 tollar. Võtaks ka mõne kilovati kohe.
insippo
Re: tuulegenekas
- sashaobrok
Re: tuulegenekas
insippo
Re: tuulegenekas
- sashaobrok
Re: tuulegenekas
insippo
Re: tuulegenekas
Re: tuulegenekas
Arvatavasti kui tehaselt konteineri täis tellida oleks hind parem.
insippo
Re: tuulegenekas
- sashaobrok
Re: tuulegenekas
insippo
Re: tuulegenekas
- Our solar panel's Specific parameters.pdf
- paneelide hinnad
- (416.44 KiB) Allalaaditud 415 korda
if you need samples to build solar panel first, I would commend the efficiency 15.95% solar cell.
The price would be USD1.45/watt, and the total price would be USD1.44*2.37*100=341.28, and the shipping carriage is USD70.
And I can offer you the price would be USD400.
kas on odavam kui meil?
insippo
Re: tuulegenekas
- sashaobrok
Re: tuulegenekas
Re: tuulegenekas
2 aastat tagasi tundus, et kui vennikesed oma masinavärgi käima saavad, siis võivad teised pillid kotti panna. Aga ega teisedki ei maganud - muud thin-film ja ka ränipaneelide tootjad on oma asja samuti efektiivsemaks muutnud ja hinda alandanud. Esimesena teatas ametlikult paneelide tootmishinna langemisest alla 1USD/Wp kohta üks suuremaid tegijaid First Solar selle aasta veebruaris vist . Ja viimastel kuudel on järjest tulnud uusi uudiseid teiste nanotintide leiutamisest - kaasaarvatud räni baasil. (http://www.solarserver.de/solarmagazin/ ... l#news1022 vt.17.09.uudis "JA Solar.. ..")
2009 on Nanosolarilt blogis uudiseid vähem - ilmselt tegelesid nad paneelitehase ehitusega Saksamaal (avati 09.09.09) ja kui tegelik äri juba käib ei sobi klientide ees samuti pidevalt kilgata, et toodame 0,3 dollariga aga sulle müüme 5 korda kallimalt.
Oluline on see, et tehnoloogia areneb ja paneelide hind kukub. Kui mitte täna kohe siis homme-ülehomme.
NB! katsuge ikka vahet teha celli ja paneeli vahel.
insippo
Re: tuulegenekas
